Configuring Lot Numbers for Other Products
In the preconfigured application, only products of type Sample, Device, and Equipment can be tracked by lot numbers.
To activate lot number tracking for other types of product
  • Use Siebel Web Tools to edit the Lot Tracking Product Types user property of the Internal Product business component.
    For information about the Lot Tracking Product Types user property, see the following table.
    For more information on editing user properties, see Configuring Siebel Business Applications and Using Siebel Tools.
User Property Name User Property Value Description
,ProductType1,ProductType2,ProductType3,...,
ProductType is the Language Independent Code (LIC) for the product type you want to track with lot numbers.
Value must start and end with a comma and have no spaces between LICs.
Example: ,Sample,Equipment,Device,
Enables lot tracking for specified product types.
