Defining Product Features
This task describes how to define product features in the Product Features view.
To define product features
  1. Navigate to the Administration - Product screen, then the Product Features view.
  2. In the Product Features list, create a new record and complete the necessary fields.
    Some fields are described in the following table.
    Field Comments
    Category
    The category in which this product feature is classified.
    Product Line
    Select the product line of which this product is a part.
    Name
    The product feature criterion; for example, Once a Day Formulation.
    Description
    A description of the feature, if necessary.
