Setting Up Primary Specialties
As a Siebel administrator, you are responsible for defining and entering the primary specialty information about contacts.
The Primary Specialty field is read-only and can be edited only through EIM. The list of specialities is defined in the Administration - Application screen, Speciality view.
Note: The Primary Specialty field is different from the Rep Specialty
field on the Contacts screen. To create additional values for the
Rep Specialty drop-down list, follow the procedures on modifying a
list of values in the Siebel Applications Administration Guide.
This task is a step in Process of Managing Contacts.
