Deleting Batch Engine Parameters
After you have used batch engine parameters in a run and you do not want them to apply to following runs, delete them using the following procedure.
To delete batch engine parameters
Navigate to the Administration - Loyalty Programs screen, Engine Parameters view.
Click the Transaction Parameters, Tier Parameters, Bucket Parameters, or Statement Parameters view tab.
Delete Parameter records.
Shut down and restart the server component.
