Providing Point Blocks for Loyalty Promotions
To provide points to members who use a promotion, you can:
  • Draw points from existing point blocks of the host company or partner. If you do not want to limit the number of point blocks that a promotion can distribute, then you select Unlimited in the Point Limit Type field of the Promotion record, so points are taken from the point blocks of the host company or the partner who owns the promotion. Then you must check to make sure that there are enough points to support the promotion.
  • Create point blocks specifically for a promotion. If you want to limit the number of point blocks that a promotion can distribute, then you select Limited in the Point Limit Type field of the Promotion record, so points are only taken from point blocks created specifically for the promotion. Then you must create the point blocks for the promotion.
This task is a step in Process of Creating Loyalty Promotions. This task applies only to reward promotions.
