Setting Up a Loyalty Product Offering
The following procedure describes how to set up a loyalty product offering. You can specify the pricing method for each product offering: points, points by zone, or points by distance.
To set up a loyalty product offering
  1. Navigate to the Loyalty Program Administration screen, Programs view, click the Program Id hyperlink for the partner program, then click the Partners tab.
  2. Click the row for the partner you want to work with, then click the Loyalty Product Offerings tab.
  3. For each product you want to add, click New, then complete the necessary fields. Some fields are described in the following table.
    Field Description
    Product
    From the picklist, select the product for accrual, then click OK.
    Start Date
    Enter the earliest date for this product.
    End Date
    Enter the last date for this product.
    Offer Type
    Choose from two options: Accrual or Redemption.
    Accrual Template
    Select a template from the picklist.
    Pricing Method
    Choose from three options: Points, By Zone, or By Distance.
