Adding Products to Catalogs
You add products to catalogs by associating them with categories that belong to those catalogs.
Note: Before you can perform this step, you must define products. For information on defining products, see Siebel Product Administration Guide.
This task is a step in Process of Setting Up Categories.
To associate a product with a category
  1. Navigate to the Administration - Catalog screen, then the Catalog Administration view.
  2. Click the Name link for a catalog.
    The Categories list displays the categories belonging to that catalog.
  3. Select a category with which to associate products.
  4. In the link bar for the category, click Products.
    The products associated with the category appear.
  5. Add a new record to the Products list.
    The Add Internal Products dialog box appears.
  6. Select products, and then click OK.
    The products are associated with the category and appear under the Products tab.
