Configuring Error Messages in Codepage Conversion
You can perform the following configurations related to codepage errors:
  • You can configure the eSales - Complete Checkout Process workflow so that the order process stops when a codepage error is returned by Taxware. The default behavior is to allow the order process to continue.
  • You can configure the error messages displayed in the Quote Summary and Order Confirmation views of your employee application.
  • You can change the error messages that are displayed to customers on the Quote Form applet - Summary (eSales) applet and Order Form Applet - Confirmation (eSales) applet of your Siebel eSales Web site.
To configure error messages in codepage conversion
  1. In Siebel Tools, select either the Quote Form - Summary (eSales) applet or Order Form Applet - Confirmation (eSales) applet.
  2. Select Applet User Prop in the Object Explorer.
  3. Replace the EAI Error Message text with the text of your choice in the user property that has the value LabelTaxNotCalculated.
