Assigning a Partner Port for Real-Time Shopping Cart Transfer
To set up real-time shopping cart transfer, in addition to setting up inbound and outbound Web services, you must assign a port to the partner. If you are not using middleware, you might want to set up a different port for each partner.
To assign a port to the partner for real-time shopping cart transfer
  1. Navigate to the Administration - Partner screen, then the Registered Partners view.
  2. Drill down on the partner company.
  3. Navigate to the Integration view.
  4. In the Integration list, add a new record and select the port you created in the Outbound Web Services list.
