Setting Up Related Partner Programs
Related programs are programs that have a relationship with a base partner program. There are two types of related programs:
  • Addenda. These programs are is not in the original agreement. For example, a base program that authorizes partners to be resellers might have addenda programs for each product the partners can sell. After a partner is a member of the base program, that partner can apply for the addenda programs; if the partner tries to apply to addenda programs without being a member of the base program, an error message is displayed.
  • Prerequisite. This relationship is informational only. You can enter information here to tell partners that program A is prerequisite to program B, but the Siebel Business Application does not enforce this logic. To enforce this prerequisite, you must also make program B an addendum to program A.
This task is a step in Process of Setting Up Partner Programs.
To set up an addenda program
  1. Navigate to Partner Programs screen, then the Program Design view, and create a new program.
    This is the addenda program, and it is created like other partner programs.
  2. In the Partner’s Program list, drill down on the name of the base program to which you want to relate the addenda program.
  3. Navigate to the Related Programs view, add a new record to the list.
    1. Select the addenda program you created.
    2. As the Relationship Type, select Addenda.
