Creating Resources as Products
This task is a step in Process of Creating Rate Lists.
Before you create any rate list, you must create the resources that the rates apply to as products in the Product Administration screen. For example, if you run a temporary help agency, then you might create products named word processing operator, data entry clerk, secretary, and so on.
You must:
  • Create the products.
  • Associate each product with its product lines.
Note: To use these products as resources in the rate list, you must select the Project Resource check box when you create the product in the Product Administration screen.
For more information about creating products, see Siebel Product Administration Guide.
