Manual Signal Modifications for Siebel Business Applications and Industry Applications
Note: If you automatically enable the Dynamic Pricing Procedure for
all signals as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to implement any of the
modifications outlined in this topic.
This topic lists the manual signal modifications required to implement dynamic pricing for Siebel Business Applications and Industry Applications. For each signal definition, you can modify the parameters of the actions listed. If multiple actions are listed for the signal, then make sure that you modify the parameters for each of the actions listed.
Note: In some cases, the signal definition includes additional actions
and parameters that are not listed. The following actions and parameters
are the only ones that must be changed to implement dynamic pricing.
