ProductRecommendation
The following tables describe the signal action and list the parameter that you must modify to implement dynamic pricing for the ProductRecommendation signal.
Definition Service Type Service Name Mode Instance Type
Action
Workflow
Product Recommendation Driver Workflow
Not applicable
Line Item
Name Value
SubPSPPricingWFName
Dynamic Pricing Procedure
