Specifying Price Adjustments for Individual Products in a Product Promotion
Use the following procedure to specify price adjustments for individual products in a product promotion.
To specify price adjustments for individual products in a product promotion
Navigate to the Administration - Product screen, then Product Promotions view.
In the Product Promotions list, select the promotion for which you are specifying pricing.
Click the Pricing view tab.
Click Components on the link bar in Pricing view.
In the Pricing Components list, add a record for each product whose price will be changed by the promotion and complete the necessary fields as described in the following table.
Field Comments Product Name
Select a product.
Adjustment Type
Select the type of price adjustment applied to this product. The options are Discount Amount, % Discount, Markup Amount, % Markup, and Price Override.
Adjustment Value
Enter the value of the Adjustment. How this value is used depends on the selection in the Adjustment Type field:
Discount Amount. The adjustment value is subtracted from the product price.
% Discount. The adjustment value is a percentage of the product price, which is then subtracted from the product price.
Markup Amount. The adjustment value is added to the product price.
% Markup. The adjustment value is a percentage of the product price, which is then added to the product price.
Price Override. The adjustment value is used as the product price, overriding the original price.
