Assigning the New Base Theme Template
To assign the new base theme template to the customizable product, you first add the template to the Pick UI Style dialog box. Then you select it as the base theme.
Click the magnifying icon.
This opens the Pick User Interface Style window.
Click the plus icon (+).
In the Template field, click the magnifying icon.
In the Query field, enter an asterisk (*) to list all Base Template templates.
Select the template you created in Creating a New Base Theme Template.
In the Pick User Interface Style window, enter the following information:
Name. Enter a descriptive name. For example: Modified Base Theme.
Template. Enter the filename of the template you created.
Description (Optional). Enter a brief description of the template.
Click Save and OK.
