Associating Attributes with a Product
To associate attributes with a product, you assign the product to a product class. The product inherits all the attributes of the product class or subclass to which it is assigned.
This task is a step in Process of Creating Products with Attributes.
Note: Before you associate the product with a product class, you must create the product, as described in Basic Product Administration.
To associate a product with a product class
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Versions list, in the record for the Work Space version, in the Product Class field, select the product class.
