Available Siebel Configurator APIs
Three main groups of APIs are used for accessing Siebel Product Configurator:
Group 1: UI
CPRUI Service API as Siebel Web Template items.
DOM API within the browser inherent in JavaScript and HTML.
Group 2: Model
Scripts that execute in the context of the current session and are implemented as part of the configuration model in the Scripts view.
Group 3: Instance
This API is for using Siebel Product Configurator or for manipulating the configuration session from a place other than the Siebel Product Configurator runtime UI.
The Remote Complex Object Instance Service is a business service that is available for accessing the Instance API.
Note: For more information on debugging the Configurator APIs, see
see 2037936.1 (Doc ID) on My Oracle Support.
