Constrain Relationship Quantity Template
The Constrain Relationship Quantity template has the form:
[The quantity of a relationship] [=] [a value]
The quantity of a relationship is the total number of items that have been added to the solution from the relationship. For example, a relationship contains Item A and Item B. If there is one Item A and one Item B in the solution, then the relationship quantity is two. If there are two of Item A in the solution and no Item Bs, the relationship quantity is also two.
The operator, [=], defines how the relationship quantity is related to the third operand, [a value]. The operator is limited to numeric comparisons (=, <, >, and so on).
The [a value] operand can be any of the following:
  • The quantity of a product in the solution
  • The quantity of items from another relationship in the solution
  • The quantity of items in the solution from a class within a relationship
  • The value of an attribute (the data type for the attribute must be number or integer)
  • A number
The "Insert a" tab provides two sets of arithmetic functions that allow you to combine these items into expressions. For example, you could write the following constraint:
The quantity of Items from Items relationship <= (2 * [Training Classes "Intro Course" Items-limit-attribute])
The first operand is the relationship: "The quantity of Items from Items relationship." The operator is "<=". The second operand is the "Items-limit-attribute."
This constraint states that the quantity of items from the Items relationship must be less than or equal to twice the value of the "Items-limit-attribute" of the Intro Course. The Intro Course is located in the Training Classes relationship.
Use Constrain Relationship Quantity constraints to set limits on the quantity of products from a relationship that can be in the solution. The limits can be defined as a number or as the quantity of other items, or the value of an attribute.
