Constrain Template
The Constrain template has the form:
Constrain [an expression] to be true
The constraint template is useful for making simple comparison or quantity expressions into top-level constraints. For example, you want make sure that there are exactly 4 of Item B in every solution:
Constrain [Item B = 4] to be true
You can also use the Constraint template to create exclude and require constraints that have only one operand. For example the following constraint excludes Item B from the solution:
Constrain [Item B =0] to be true
To require at least 1 Item B in the solution:
Constrain [Item B >= 1] to be true
By using Compound Logic operators, you can yoke conditions together and then allow or disallow the combination. For example, you want to make sure that if the quantity of Item A > 4 in the solution, then Item B must be less than 5, and conversely:
Constrain [Item A > 4 AND Item B < 5] to be true
