Constraint Template Translations
The following table shows examples of the constraint templates translated into Rule Assembly Language.
Template RAL Equivalent Explanation
Constrain
con(>(Item A),1))
Constrain (quantity of Item A> 1) to be true.
Constrain Conditionally
if(>(Item A), 1), >= (Item B), 2), excl(Item C, Item D))
When (quantity of Item A> 1)(quantity of Item B >= 2), otherwise Selection of Item C excludes selection of Item D.
Constrain Product Quantity
==(Item A, 2)
The quantity of Item A = 2.
Consume
inc(*(Item A), -(1)), Resource B)
Each Item A consumes 1 from Resource B.
Exclude
excl(Item A, Item B)
Selection of Item A excludes selection of Item B.
Exclude List
excl(Item A, Item B, Item C))
Item A excludes (selection of Item B, selection of Item C).
Message
msg(>(Item A, 1))
When (Item A > 1), display this constraint's description.
Preference
prefer(Item A, 1)
When possible, constrain Item A is selected to be true with a priority of 1.
Provide
inc(*(Item A), 1), Resource B)
Each Item A provides 1 to Resource B.
Recommends
chk(req(Item A, Item B), "Item B is recommended")
Selection of Item A recommends selection of at least one Item B by displaying "Item B is recommended".
Requires
req(Item A, Item B)
Item A requires Item B.
Requires (Mutual)
eqv(Item A, Item B)
Item A requires Item B AND Item B requires Item A.
Constrain Attribute Value
==(@.[Class A] ([Item B]).[Day], "Monday")
The attribute Class A "Item B" Attribute C = Monday.
