Customizable Product Access Operators in Rule Assembly Language
Customizable Product access operators, shown in the following table, allow you to obtain information about other areas of the customizable product. For example, you can obtain the name of an item's parent.
Operator | Syntax | Properties |
Product root |
Result is root of the customizable product. Takes no arguments. |
