Defining the Contents for Scenario Testing
When you define the contents for the scenario, you specify all the products, attributes, classes, signals, and variable maps whose workspace versions will be tested. For these objects, the testing date from the joint workspace will not be in effect.
For example, this list can include one customizable product plus all the component products, product attributes, and product classes that are part of that customizable product. In more complex cases, it can include several customizable products and component products, product attributes, and product classes that are part of it.
This task is a step in Process of Testing Products with Scenario Tester.
To define the contents for the scenario test
  1. Navigate to the Administration - Product screen, then the Workspace Projects view.
  2. In the Workspace Projects list, select the workspace project for this scenario test.
  3. Click the Contents view tab.
  4. In the Contents list, click Add to add a new record.
  5. In the Select Versioned Object dialog box, select an object.
  6. Continue to add new records and to select new versioned objects until you have selected all the objects to be tested.
