Deleting Product Versions
If you no longer want to use a version, you can release a new version to replace the version you do not want to use, as described in Replacing Earlier Product Versions.
If you have a large number of inactive versions for a given product, you can delete the versions using the CleanupSingleObject method of the ISS Authoring Import Export Service. For more information, see Siebel Order Management Guide.
