Disabling the Proceed Button
The Proceed button is available after the user clicks the Turn Off Quick Edit button to display conflicts among the components already added.
If there are incompatible components and the user clicks Proceed, Siebel Product Configurator might display one incompatible component in red or might remove one incompatible component. The product administrator can disable the Proceed button, if users might be confused by this behavior.
Disabling the Proceed button applies only when the Quick Edit mode is turned on. Because the user can make multiple selections before validating the configuration, the constraint engine cannot determine which user action caused the conflict, so the Proceed button is disabled. However, when the quick edit mode is turned off, each user action is evaluated by the constraint engine, so the engine knows which action causes a conflict; in this case, the Proceed button is enabled.
To disable the Proceed button
Navigate to the Administration - Product screen, and then the Product Definitions view.
In the Products list, select the root product and lock it if necessary.
In the Versions list, click the Workspace hyperlink.
Navigate to the Properties view.
Add a new record to the Properties and complete the necessary fields as described in the following table.
| Field | Comments |
Name  |
Enter DisableProceed.  |
Value  |
Enter Y.  |
When the sales agent configures the product, the Proceed button is disabled and grayed out.
