GetLinkItemValues Method
This method retrieves the linked item values. Use it as follows:
Clear the cache values if specified by the caller.
For the search specification set by the caller:
If only RootProductId is given and no child property sets are given, try to find only the values for LinkItems that are under the given RootProductId.
If both RootProductId and Child Property Sets are given, try to find only the values for LinkItems that are defined in the child property sets.
Input Arguments
ClearValues. Y or N. Clears all cached Link Item Values.
GetAllValues. Y or N. Gets all values from the cache or only the values passed in for the search specification.
RootProductId. Root Product Id.
LIVersionId. Root Product Version Id (optional).
Child Property Set (0) Type: LinkedItem:
ProductId. Product Id
VersionId. (optional) Version Id
InClass. Y or N.
LinkItemId. Link Item Id
Child Property Set (1) Type: LinkedItem:
ProductId
VersionId (optional) Version Id
InClass. Y or N.
Output Arguments
Each linked item is returned as a child property set as follows:
Child Property Set Type: LinkedItem:
CxLnkItmId. Link Item Id.
CxLnkItmName. Link Item Name.
CxLnkItmDesc. Description.
CxLnkItmDef. Definition.
CxLnkItmIsActive. IsActive Flag.
CxLnkItmValue. Value.
CxLnkItmDisplayValue. Display Value.
CxLnkItmType. Type.
CxLnkItmProductId. Product Id where this linked item is defined.
CxLnkItmVersionId. Version Id of the previous product.
