Quantity Conditions
Quantity conditions compare the quantities of two items. Depending on the session context in which a quantity condition is evaluated, it either returns true/false or is enforced as a constraint.
For example you write the following configuration constraint,
(Product A > Product B) excludes Product C
Context A. If the user picks Product A so that its quantity is greater than Product B, then Product C is excluded. In this case, the quantity condition is evaluated as true/false, and Product C is excluded when it is true.
Context B. If the quantity of Product A in the solution is not greater than Product B and the user picks Product C, then the quantity condition is enforced as a constraint. In all further solutions, the Siebel Product Configurator engine will require that the quantity of Product A is < = Product B if Product C is present.
