Setting the Server Parameter to Enable Pre-Pick Compatibility
Use the following procedure to set the server parameter to enable pre-pick compatibility.
To enable pre-pick compatibility
  1. Navigate to the Administration - Server Configuration screen, then the Servers and Parameters view.
  2. In the Server Parameters list, query to find the parameter Order Management - PrePick Compatibility.
  3. In the Value field for this parameter, enter True.
    The Value on Restart field also changes to True.
