Translating Attribute Definition Names
You can translate the name of an attribute definition, so it is displayed to end users in their own language.
To translate an attribute definition
  1. Navigate to Administration - Product screen, then the Attribute Definitions view.
  2. In the Attribute Definitions list, select and lock the desired attribute definition.
  3. In the Versions list, click the name of the Workspace version.
  4. In the Attribute Values list, select an attribute value.
  5. In the Attribute Values Display Names list, add the new records, and complete the necessary fields, as described in the following table.
    Field Comments
    Display Name
    Enter the translation of the attribute definition name.
    Language
    Select a language code.
  6. Continue to enter translations for all the values of this attribute.
