Translating Product Class Display Names
You can enter translations of the names of product classes, so they are displayed in the language of the end user. To translate a class display name
  1. Navigate to the Administration - Product screen, then the Product Classes view.
  2. Select and lock product class whose attributes you want to translate.
  3. In the Versions list, click the Work Space version.
  4. Click the Display Name view tab.
  5. Add a new record to the Display Name list and complete the necessary fields, as described in the following table.
    Field Comments
    Display Name
    Enter the translation of the display name.
    Language
    Select a language code.
  6. Repeat Step 5 to create additional language translations for the class display name.
