Translating UI Group Names
Use this procedure to translate group names that display in customizable product selection pages.
To translate a UI group name
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired customizable product.
In the Versions list, click the Work Space version.
Click the User Interface view tab.
In the User Interface view, click the Name of the UI group whose name you want to translate to drill down on it.
From the Group List menu, choose Translate Groups.
The Group Name Translations dialog box appears.
In the dialog box, add a new record and complete the necessary fields, as described in the following table.
Field Comments Language
Select a language.
Name
Enter the translation of the group name.
Repeat Step 7 to create additional translations for this UI group name.
