Verifying the Variable Map for Pre-Pick Compatibility
Verify that the needed variable map definition is present for the following two variable maps:
Product Eligibility Variable Map - Context
Cfg Eligibility Variable Map - Context
To verify the variable map
Navigate to the Administration - Order Management screen, then the Variable Maps view.
Query to find the variable map named Product Eligibility Variable Map - Context.
Drill-down on this variable map.
In the Variable Map Definitions list, query to find Pre Pick Compatibility.
If this definition is not found:
Lock the variable map.
Add a new record to the Variable Map Definitions list and complete the necessary fields, as described in the following table.
Field Value Variable Name
In/Out
In
Type
Boolean
On Null
Ignore
Add a new record to the Variable Source list and complete the necessary fields, as described in the following table.
Field Value Mode
Any
Path
PARAM_OM_PREPICK_COMPATIBILITY_FLAG
Source Type
Server Parameter
Add another new record to the Variable Map Definitions list and complete the necessary fields, as described in the following table.
Pre Pick Mode
In/Out
In
Type
Text
On Null
Ignore
Field Value Mode
Any
Path
$Current/Header/Pre Pick Mode
Source Type
Instance
Release the variable map.
Repeat Step 1 to Step 5 for the variable map Cfg Eligibility Variable Map - Context.
Clear the Cache.
