Working with Versioned and Unversioned Objects
Scenario Tester can test:
Versioned objects. You can test customizable products, classes, and attribute definitions.
If the objects are part of the active Workspace Project, Scenario Tester uses the version in the Workspace Project, even if it is unreleased.
If objects are not part of the Workspace Project, Scenario Tester uses the released version of the object.
Note: Scenario Tester uses objects that are not part of the Workspace Project if objects that are part of the Workspace Project are dependent on them. For example, if you add a product with attributes to the Workspace Project, but do not add the Class that the product inherits its attributes, Scenario Tester uses the released version of that Class.
Unversioned objects. Scenario Tester tests the eligibility, compatibility, and pricing rules for unversioned objects, using the Base Date to determine whether a particular item must be retrieved.
