Mobile Products That Siebel CRM Supports
The following table describes mobile products that Siebel CRM supports.
| Product Group | Supported Application | Reference |
Siebel Remote |
Siebel Remote supports almost all Siebel CRM applications. |
You can use the following reference sources:
Siebel Mobile Applications |
Siebel Mobile connected applications Siebel Mobile disconnected applications |
