Data Transformation Engine Factory Class Methods
The Data Transformation Engine Factory Class (CSSFAELDTEService) provides the methods described in the following table that you can overwrite.
Method Description
PreProcess
Allows application developers to modify or reserve information within the integration object instance.
PostProcess
Allows application developer to modify or restore stored information into the integration object instance.
ProcessMessage
Allows application developer to process information within the root tag of message.
ProcessHeader
Allows application developer to process information within the header portion of message.
