Industry XML Data Transformation Engine
The Industry XML Data Transformation Engine transforms the hierarchy between external and internal data models that are represented by integration object instances. The Industry XML Data Transformation Engine is designed to handle heterogeneous messages to allow more than one business object scenario. It also takes extra input arguments specified in the data transformation map to indicate the possibility of removing empty value tags from the instances transformed.
The following table lists the specific methods for the Industry XML Data Transformation Engine.
Methods | Display Name | Description |
ToExternal |
Transform To External Hierarchy |
Transforms Siebel internal integration object hierarchy into the industry XML external hierarchy. |
ToInternal |
Transform To Siebel Hierarchy |
Transform industry XML external hierarchy into the Siebel internal integration object hierarchy. |
The Industry XML Data Transformation Engine business service uses combinations of method, and method arguments to achieve different tasks. The following table lists all the method arguments available to use with the Industry XML Data Transformation Engine business service.
Argument | Default Value | Description |
XMLHierarchy |
N/A |
Property set in internal or external integration object hierarchy. |
<MapArgs> |
N/A |
See Business Processes and Rules: Siebel Enterprise Application Integration. |
Each method defined for the Industry XML Data Transformation Engine business service takes some input arguments and produces some output arguments as listed in the following tables.
Name | Display Name | Data Type | Type | Optional |
XMLHierrarchy |
XML Property Set |
Hierarchy |
Input/Output |
No |
<MapArgs> |
String |
Input |
Yes |
XMLHierrarchy |
XML Property Set |
Hierarchy |
Input/Output |
No |
<MapArgs> |
String |
Input |
Yes |
