Example Command Using $RemoteConnectStr
The example command and command data definitions shown in the following table and the second table in this topic, using the $RemoteConnectStr macro, use the Owner Phone field in the Service Request business component to determine which call center has the phone number. In this example, the Param.RemoteConnectStr command parameter gets the extension number for the call recipient by macro-expanding Owner Phone:Lookup. The Siebel application looks up which configuration has this extension and returns the name of the call center with this extension.
| Parameter Name | Parameter Value |
Description |
Blind Transfer to Service Request Owner |
DeviceCommand |
TransferMute |
Hidden |
True |
The following table shows a command data definition for this command definition.
BusComp |
Service Request |
RequiredField.'Owner Phone' |
Param.PhoneNumber |
{Owner Phone:Lookup} |
AttachContext |
True |
Param.CallNotifyText |
Blind transfer from {@UserName} about SR {Id}... |
Param.RemoteConnectStr |
{$RemoteConnectStr(Owner Phone:Lookup)} (In this example, Owner Phone is a field from the Service Request business component.) |
