Cleaning Up the File System Directories Using the sfscleanup Utility
This topic describes how to clean up the Siebel File System directories
by removing orphan records using the Siebel File System cleanup utility, sfscleanup.
This topic is part of Cleaning Up the Siebel File System.
To clean up the file attachment directory using sfscleanup
At the command prompt, change directory to the
binsubdirectory within the Siebel Server root directory.Run
sfscleanupusing parameters listed here, in a command like the following example:sfscleanup /U sadmin /P pwd /F \\server1\files /X \\server1\logs\sfscleanup.logFor more information about the parameters you can use for the
sfscleanuputility, see Parameters for the sfscleanup Utility.
About the sfscleanup Log File
If you specified
an output file using the /X parameter, then sfscleanup generates a log file listing the operations that were performed.
The output file is a tab-delimited text file that contains the following
columns:
File Name. This column lists the name of each file that was processed.
File Type. This column lists the type of each file that was processed.
Operation. This column lists the type of operation that was performed during processing. A table later in this topic provides descriptions of each operation.
File Types and Operations for the sfscleanup Utility
The following table lists the possible file types and the associated
operation performed by sfscleanup during processing.
The Operation column lists the type of operation that was performed
during processing.
File Type |
Description |
Operation |
CURRENT |
The file has a corresponding record in the file attachment database table. |
KEPT |
NEW |
The file is less than one hour old. The |
KEPT |
ORPHAN |
The file does not have a corresponding record in the file attachment database table. If you used the /M parameter to set a move directory, then the operation performed is MOVED, not DELETED. |
DELETED |
INVALID |
The file (or directory) is not a file attachment.
If If you set the /G parameter to Y, then the operation performed is DELETED, not KEPT. |
KEPT |
ANCIENT |
The file has an associated record in the database with a different revision number. If you set the /N parameter to Y, then the operation performed is either MOVED (if you used the /M parameter to set a move directory) or DELETED, not KEPT. |
KEPT |
The operations mentioned in the previous table are described in the following table.
Operation |
Description |
KEPT |
The file was kept. |
DELETED |
The file was deleted. |
MOVED |
The file was moved to the directory specified by the /M parameter. Files are moved if you used the /M parameter. |
KEPT_DIR |
The item was kept because it was a directory and requires manual processing. |
KEPT_ERROR |
The file was kept because an error occurred while trying to move or delete the file. |
