Deleting System Parameter Overrides
As previously described, lower-level system parameters inherit values from the same higher-level system parameters. However, modifying a lower-level parameter value sets an override at this level. That is, the lower-level parameter loses the ability to inherit values from higher-level parameters. To reinstate the default functionality, perform a delete parameter override operation on affected parameters. This topic is part of Advanced Configuration Tasks.
The following procedures describe how to delete parameter overrides for Siebel Enterprise Server parameters, Siebel Server parameters, component definition parameters, and Siebel Server component parameters.
This topic contains the following information:
Deleting a Parameter Override for a Siebel Enterprise Parameter
Deleting a Parameter Override for a Siebel Server Parameter
Deleting a Parameter Override for a Component Definition Parameter
Deleting a Parameter Override for a Siebel Server Component Parameter
