Parameters for DataSources Section
The following table lists data sources in the Siebel configuration file, which appear in the [DataSources] section. Each data source also has its own section specifying parameters that apply to this data source.
Name
Function
Local
Defines parameters for connecting to the local database.
Sample
Defines parameters for connecting to the sample database.
ServerDataSrc
Defines parameters for connecting to the Siebel database.
GatewayDataSrc
Defines Siebel Gateway parameters.
Note: If you want to prevent a data source from being displayed as a choice in the Connect To: portion of the Siebel login screen, then add two slash characters (//) in front of the data source in the [DataSources] section of the configuration file. For example: //Sample = Sample.
