Enabling Oracle Business Intelligence Publisher for Test Automation
To enable Oracle Business Intelligence Publisher (BIP) for Test Automation, you must enter the BIP specific parameters. As a prerequisite, ensure that BIP is integrated with Siebel prior to test execution.
The format for entering the parameters in Batch mode and Unit mode are given in the following subsections.
Batch Mode
Enter the information in the following table in the Test Execution screen.
Field |
Description |
Sample Value |
BIP Outbound WS URL |
BIP outbound Web service. |
http://slcxxxxxx:9502/xmlpserver/services/publicreportservice_v11 |
BIP Server Machine |
Name of the BIP server. |
slcxxxxxx |
BIP Server Port |
Port number for BIP server. |
9502 |
BIP XMLP Server Machine |
Name of the XMLP server. |
None. |
BIP XMLP Server Port |
XMLP port number. |
None. |
BIP Server User |
BIP server user name. |
None. |
BIP Server Password |
BIP server password in plaintext. |
None. |
Unit Mode
Update the following parameters in the unitconfig.xml file:
<BIP-OUTBOUNDWEBSERVICE>http://slcxxxxxx:9502/xmlpserver/services/publicreportservice_v11</BIP-OUTBOUNDWEBSERVICE><BIP-SERVERNAME>slcxxxxx:9500</BIP-SERVERNAME><BIP-SERVERXMLP>slcxxxxx:9502</BIP-SERVERXMLP><BIP-USERNAME>SADMIN</BIP-USERNAME><BIP-PASSWORD>ldap</BIP-PASSWORD>
C:\DISA\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Framework\lib. After installing DISA, the bip.pl will be available in the following location:
<DISA Install location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Framework\perlTo perform BIP Automated script execution, you need to move the bip.pl to the following (folder) location:
<DISA Install location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Resources\invokeperlUsing BIP Automation, you can verify all Interactive, Scheduled, and Parameter based report generation.
