Grouping Test Sets into a Master Suite
The following procedure shows how to group test sets into a Master Suite.
This task is a step in the Process of Implementing Siebel Open UI Keyword Automation Testing.
To group test scripts into a Master Suite
  1. Navigate to Sitemap, Release screen, then the Master Suites view.
  2. Click the plus (+) icon to create a new test set.
  3. In the form that appears, complete the fields with the values shown in the following table.
    Field Description Sample Value
    Name
    Name of the test set
    xyz
    Description
    Description of the test set
    Test
    Status
    Status of the test set
    Active
    Test Plan ID
    ID associated with the test set
    Test1_001
    Team
    Specifies the corresponding name of the team.
    Titans, Transformers, and so on.
    Release
    Specifies the appropriate release version.
    17.0
  4. Drill down on a value in the Name field, then click Add Test Sets (or the plus (+) icon) to associate test sets with the selected Master Suite.
  5. If the master suite contains the following keywords, you must add the required files in the respective folders.
    • Folder Name: Resources
    • Keywords:
      • Inboundwebservicecall
      • Invokeperl
      • Serverconfig
      • fileupload
After including the files, you can zip the folder (that is, Resources.zip) and attach Resources.zip in the MasterSuite Attachments Applet.
