Setting Up the Automation Adapter
Before you get started with the task of recording a functional flow, you must complete the procedures in this topic to set up the system preferences and profile configuration parameters for Usage Pattern Tracking. You must also delete UPT action sets, runtime events and system preferences.
To set the system preferences for Usage Pattern Tracking
Navigate to the Administration - Application screen, then the System Preferences view.
Set the system preferences as shown in the following table:
Name Value Enable UPT
True
Enable UPT Context
True
UPTMax Record Cache
100
To implement the system preferences, you must restart the Siebel Gateway and Siebel Services.
To set the profile configuration parameters for Usage Pattern Tracking
Navigate to the Administration - Server Configuration screen, then the Enterprises view.
In the Enterprises Server applet, select the enterprise server you want to configure.
Click the Profile Configuration tab. Query for the profile AutomationSubSys.
Name Alias Datatype Value Class Path
CLASSPATH
String
N/A
Container URL
CONTAINERURL
String
The value for the jbs. For example:
CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbsThe
<ContainerPort>value should be taken from the following:<Siebel_Install_Location>\ses\applicationcontainer_external\conf\server.xml<Connector port="4730" protocol="HTTP/1.1"For Example:
http://localhost:4730/siebel/jbs.-
To implement the profile configuration changes, you must restart the Siebel Gateway and Siebel Services.
To configure the AutomationSubSys profile via the server manager command
Enter the following server manager command to configure the profile for AutomationSubSys:
change param CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbs for named subsystem AutomationSubSysThe following table lists the runtime events configured out of the box.
Sequence Object Type Event Action Set Name Conditional Expression 2
Application
ViewActivated
KWD
GetProfileAttr("Enable Recording") = "True" AND GetProfileAttr("RecordingOn") = "True"2
Application
ViewDeactivated
KWD
Application
WebLogin
KWD
Application
WebLogout
KWD
Applet
PreInvokeMethod
KWD
Application
Recording
KWD
GetProfileAttr("Enable Recording") = "True"2
Application
InvokeServiceMethod
KWD
Application
UPTClientScript
KWD
GetProfileAttr("EnableRecording") = "True" AND GetProfileAttr("RecordingOn") = "True"2
Application
InvokeMethod
KWD
To delete UPT action sets, runtime events and system preferences
To delete events set to UPT:
Navigate to the Administration - Runtime Events screen, then the Events view.
Delete all the Events with Action Set Name set to UPT:
'Action Set Name' = UPT. -
Click Applet Menu and then click Reload Runtime Events.
To delete action sets set to UPT:
Navigate to the Administration - Runtime Events screen, then the Action Sets view.
To delete UPT system preferences:
Navigate to the Administration Application screen, then the System Preferences view.
Delete the following system preferences: UPTEEE1, UPTEEE2, and UPTEndToEndEventList.
For changes to take effect, log out of the application and then back in again.
Restart Enterprise Server for system preference changes to take effect.
