Marking Conflict Resolution as Complete Using Siebel Tools
This task is a step in Process of Upgrading Siebel Development Environment from Siebel CRM 8.1.1.x (SIA Repository). Use this task to mark conflict resolution as Complete.
To mark conflict resolution as Complete using Siebel Tools
After you have resolved all conflicts, execute the following command from the
$SIEBEL_HOME\bin\siebdev.exedirectory on the command prompt:$SIEBEL_HOME\bin\siebdev.exe /u SADMIN /p ******** /d <"ServerDataSrc"> /c "$SIEBEL_HOME\bin\enu\tools.cfg" /l enu /IRM UpgDeltaMerge /iPackmode -
After Siebel Tools starts, select the Conflict Resolution Completed check box.
Click Finish.
Clicking Finish creates an entry in the S_INST_UPG_HIST table, indicating that the merge and conflict resolution steps have been completed. If this step is not executed, then the next phase of upgrading the custom database schema (upgphys) produces an error in the first step.
