Preparing Siebel Territory Management Rules for Upgrade
Upgrades from: Siebel 7.8.x.
Environments: Test, Production.
Territory rules management was introduced in Siebel CRM 7.8. but since Siebel CRM 8.0, territory rules cannot have overlapping effective date ranges. For example, the following two rules have overlapping effective date ranges:
  • Rule 1
    Territory: A100
    Account: XYZ Corp
    Effective Start Date: 1/1/2006
    Eff. End Date: 6/30/2006
  • Rule 2
    Territory: A100
    Account: XYZ Corp
    Effective Start Date: 4/1/2006
    Eff. End Date:
You must identify rules with overlapping effective date ranges and modify the rules to eliminate any overlap.
To prepare territory rules for upgrade
  1. Run the following script against the database:
    Windows: DBSRVR_ROOT\common\TM_DupRuleCheck.sql
    UNIX: DBSRVR_ROOT/common/TM_DupRuleCheck.sql
    The script returns a list of all territory rules that have overlapping effective date ranges.
  2. In Territory Management, revise rule effective date ranges to remove the overlaps.
