Setting IBM DB2 Parameters for a Siebel Upgrade
Environments: Development, Test and Production.
Databases: IBM DB2 only.
Before upgrading an IBM DB2 database, verify that your database server meets or exceeds the following configuration criteria:
The DMS tablespace has at least 25% of free pages.
The file system has sufficient space to allow your DMS tablespace to grow.
Siebel tablespaces for IBM DB2 must be database-managed tablespaces (DMS) rather than system-managed tablespaces (SMS).
Verify that the tablespaces are not near their capacity. This can be done by connecting to the database and issuing the following command:
DB2 list tablespaces show detail
The tables which follow provide upgrade-specific settings for the Database Manager and database. Use the following strategy to set parameters:
Set parameters using the recommendations in Siebel Installation Guide. Recommendations are located in the chapter on configuring the RDBMS.
For the upgrade, revise the configuration parameters listed in the tables which follow.
After the upgrade, reset the configuration parameters to the values listed in Siebel Installation Guide.
