Starting Upgrade Tuner
Use this procedure to start Upgrade Tuner.
To start Upgrade Tuner
  • Enter the following command:
    SIEBEL_ROOT\bin\upgtuner /c LOGPARSE_SUMMARY_LOCATION
    LOGPARSE_SUMMARY_LOCATION is the location of the summary.xml file generated by the Logparse utility for the production upgrep. For example:
    upgtuner /c SIEBEL_ROOT\log\upgrep_prod_77\summary.xml
    The Upgrade Tuner Process Information page appears.
    Alternative: Start Upgrade Tuner without the /c option. Click OK at the error pop-up. When Upgrade Tuner displays, click Browse and navigate to the summary.xml file.
