Transferring UNIX Files for Use by Siebel Upgrade Tuner
Environments: Test environment only. Does not apply to production environment.
Platforms: UNIX only.
Upgrade Tuner is part of the Siebel Server and runs only on Windows. To tune production upgrade files on a UNIX computer you must do the following:
  • Transfer upgrade files needed by Upgrade Tuner from the UNIX host to a Windows host on which a Siebel Server is installed.
  • Run Upgrade Tuner on the Windows host using the UNIX files as input.
  • Transfer the modified upgrade files from the Windows host back to the UNIX host.
Scripts generated by the Logparse utility during the production upgrep on the UNIX host simplify the file transfer process:
  • upgtuner_ftp_get.txt. This script moves upgrade files from a UNIX host to a target directory on the Windows host.
  • upgtuner_ftp_put.txt. This script moves the upgrade files from the Windows host to a target directory on the UNIX host.
