Upgrade Planning for Siebel String Translation
Platforms: Windows, UNIX, IBM z/OS.
Based on the language for the Siebel upgrade process, the Siebel upgrade scripts are created accordingly.
When the Database Configuration Wizard is started, the sqlgen utility
generates the Siebel upgrade scripts based on the information located
in the upgfile.xml file. When the Database Configuration Wizard completes,
SQL scripts are generated, and replace the placeholders in the upgfile.xml
with the language-specific values located in the DBSRVR_ROOT/lang_code/upglocale.lang_code file.
In the following example, the locale file is upglocale.fra, for a FRA based installation. The upgfile.xml contains the following statement:
update S_DOC_QUOTE
Set the QUOTE_SUB_TYPE_CD value to '<XTL_STRING>Private</XTL_STRING>'
Where the QUOTE_TYPE equals '<XTL_STRING>Template</XTL_STRING>'
The placeholders <XTL_STRING>Private</XTL_STRING> and <XTL_STRING>Template</XTL_STRING> are
values that the sqlgen utility changes during the upgrade. The XTL_STRING
values are replaced based on what the sqlgen utility locates as a
match for the Private and Template strings in the upglocale.fra file, located under dbsrvr/FRA. For this example, the FRA base language dictates Template
= Modèle and Private = Privé.
