Use the following procedure to complete a synchronous full Runtime Repository (RR) migration without using the Siebel Migration Application.
To perform a full RR migration without using the Siebel Migration Application
Export the schema from the source environment:
Start the source application. For example: Siebel Call Center or any other employee facing application.
Navigate to the Administration - Business Service screen, then the Simulator view.
Click New (the plus (+) icon) to create a new Business Service record with the following values:
Service Name Method Name Migration Schema Service
Export
Create a new record in the Inputs Arguments list applet:
Click the multiple select button in the Property Name field, and then click the plus (+) icon on the Property Set Properties applet that appears.
Enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value migrationid
schema_export
Click OK to close the Property Set Properties applet.
Click Run.
In the Output Arguments applet, copy the value in the Property Value field for the
trackingidProperty Name.Save the value in a text file because you will need it in Step 7 later.
Make sure that the ddldict process is running.
To do this, use Task Manager on Windows or the ps command on UNIX.
Generate a watermark for the Full RR source environment:
Service Name Method Name Migration Runtime Repository Data Service
GetWatermark
Enter the following values in the Property Name and Value fields, and then click Save:
Property Name Value workspace
Enter the
<Integration_Workspace_Name>of the repository that you want to migrate -
Click the plus (+) icon in Property Set Properties applet again, enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value version
Enter the
<Version_Number>of the repository (<Integration_Workspace_Name>) that you want to migrate. -
Property Name Value language
Enter the
<language>or<language1, language2, language3, etc>that you have enabled on the database. -
Click Run.
In the Output Arguments applet, copy the value in the Property Value field for the watermark Property Name.
Save the value in a text file because you will need it in the next step (Step 3).
Export the Full RR from the source environment:
Export
repo_export
Property Name Value watermark
Paste the value that you saved from the Property Value field in the Output Arguments applet in the previous step (Step 2) into this field.
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in Step 8 later.
Make sure that the repimexp process is running.
Generate a watermark for the Full Seed source environment:
Service Name Method Name Migration Application Workspace Data Service
GetFullSeedWatermark
Property Name Value Workspace Name
Enter the
<Integration_Workspace_Name>of the full seed that you want to migrate -
Click Run.
Save the value in a text file because you will need it in the next step (Step 5).
Export the Full Seed from the source environment:
FullSeedExport
seed_export
Paste the value that you saved from the Property Value field in the Output Arguments applet in the previous step (Step 4) into this field.
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in Step 11 later.
Make sure that the dataexp process is running.
Ensure that the (Full RR and Full Seed) schema export from the source environment is complete:
At regular intervals, check that the ddldict, repimexp, and dataexp processes are running, until they complete.
Verify the logs for ddldict, repimexp, and dataexp. The logs for these utilities are stored in the following locations:
<FS_PATH>\migration\schema_export\logfor Schema Export<FS_PATH>\migration\repo_export\logfor Full RR<FS_PATH>\migration\seed_export\logfor Workspace Data -
You must wait until these three processes (ddldict, repimexp, and dataexp) are complete.
Import the (source) schema to the target environment:
Note: Perform this task only if Step 6 completes successfully.-
Copy the
schema_exportfolder from<FS_PATH>\migration\on the source machine. -
Paste the
schema_exportfolder into the<FS_PATH>\migrationpath on the target machine. -
Start the target application. For example: Siebel Call Center or any other employee facing application.
Import
schema_export
Property Name Value filename
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 1 into this field.
Property Name Value username
<Target Database Schema User Name>Note: The database schema user name is in plain text format. Contact your Siebel administrator if you do not know what the database schema user name is for the target environment. -
Property Name Value password
<Target Database Schema Password>Note: The database schema password must be in Base64 encoded format. Contact your Siebel administrator if you do not know what the database schema password is for the target environment. -
Click Run.
Make sure that the ddlimp process is running in the target environment.
Wait until the ddlimp process completes successfully.
Verify the log located in the
<FS_PATH>\migration\schema_export\logfolder on the Target machine.
Import the Full RR to the target environment:
Note: Perform this task only if Step 7 completes successfully.-
Copy the
repo_exportfolder from<FS_PATH>\migration\on the source machine. -
Paste the
repo_exportfolder into the<FS_PATH>\migrationpath on the target machine. -
Import
repo_export
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 3 into this field.
Click Run.
Make sure that the repimexp process is running in the target environment.
Wait until the repimexp process completes successfully.
<FS_PATH>\migration\repo_export\logfolder on the Target machine.
Export a SeedCopyExport from the target environment:
Note: Perform this task only if Step 8 completes successfully.-
SeedCopyExport
seed_copy
Mode=SegCopyFullMigration
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in the following step (Step 10).
Make sure that the dataexp.exe process is running in the target environment.
To do this, use Task Manager on Windows or the ps command on UNIX and wait until the process completes.
Wait until the dataexp.exe process completes successfully.
<FS_PATH>\migration\seed_copy\logfolder on the Target machine.
Import the SeedCopyImport to the target environment:
Note: Perform this task only if Step 9 completes successfully.-
SeedCopyImport
seed_copy
Paste the value that you saved from the Property Value field in the Output Arguments applet in the previous step (Step 9) into this field.
Click Run.
Make sure that the dataimp.exe process is running in the target environment.
Wait until the dataimp.exe process completes successfully.
Import the FullSeedImport to the target environment:
Note: Perform this task only if Step 10 completes successfully.-
Copy the
seed_exportfolder from<FS_PATH>\migration\on the source machine. -
Paste the
seed_exportfolder into the<FS_PATH>\migrationpath on the target machine. -
FullSeedImport
seed_export
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 5 into this field.
Click Run.
<FS_PATH>\migration\seed_export\logfolder on the Target machine.
Rename the "Migrated Repository" in the target environment – see Renaming Repositories After Full Migration.Note: It is no longer necessary to activate tasks in the target environment since tasks are now Workspace-enabled, which means you can edit them within a workspace.
