Importing with the Migration Application Data Service
You can import a Migration Application Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to import a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service/Import
HTTP Method: POST
Content-Type: application/json
Authorization: Basic
Request parameters:
filename: Use the Tracking Id value that is present in the response from Exporting with the Migration Application Data Service.
migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
Request body:
{ "body": { "filename": "Tracking Id value>" "migrationid": "Migration Id value> } }
The following are the details for the response to a successful request:
HTTP Code: 200
Response parameters:
trackingid: Returns the tracking identification value.
Response body:
{ "trackingid": "tracking id value>" }
